| Its an 8.75, I hope. But, need a better opinion. https://slantsix.org/forum/viewtopic.php?t=52595 |
| Author: | DusterIdiot [ Tue Jul 02, 2013 9:55 am ] |
| Post subject: | Yep... |
No bolts or plate in the back, so that's an 8 3/4"....she might be a 741 cased unit being that early, but plenty of options are available for that rear. The one thing to note, is that some of the early 8 3/4" had large nuts to hold the brake drums on the axle (you'll know when you take a rear tire off, you'll see it...), if you have this type of rear they are a pain to change gears in (hopefully it's a later version that did not have this feature). Good find. -D.Idiot |
| Author: | BigCarl [ Tue Jul 02, 2013 10:45 am ] |
Awesome. Thank you for the reply. I have had the brakes off and everything replaced when I purchased the car. $2000.00 off Kijiji and 800 to safety it; exhaust manifold, brake shoes, hoses, headlight bulb, signal light bulb and a windshield washer pump. When I did the brakes, the rear drums just slid off, no bolt holding them in. The fronts have the bolt and bearing. I wanted to get the diff identified because I want to put an SG in there this coming winter. Again, than you for the help. |
| Author: | Doc [ Tue Jul 02, 2013 3:15 pm ] |
Where did you get the "3.21 ratio" info? 8 3/4 has a 3.23 ratio... DD |
| Author: | BigCarl [ Tue Jul 02, 2013 4:49 pm ] |
Meant 3.23. Was a typo. |
| Author: | NCDemon1971 [ Wed Jul 03, 2013 11:02 pm ] |
That's 100% 8.75 rear. Chrysler stuff was funny like that. Often a /6 car would have a 7.25 rear but if the car was coming down the line and the 8.75 was all that was available.- the 8.75 would go in. They didn't toss them out. Most likely the Fury also had the 8.75 because of the heavier vehicle weight vs. other body styles. |
| Author: | 64ragtop [ Thu Jul 04, 2013 10:23 am ] |
I'm pretty sure that '64 was the last year for the old-style tapered axles. You got lucky there (though I think the '64's were prettier cars.) Also, I think the 8.75' rears were part of the "heavy duty" package that my dad ordered on our '62 Fury. He did pull a trailer. BC |
