It is currently Thu Nov 26, 2026 10:58 pm
PostPosted: Tue Jul 02, 2013 8:02 am
I just want to update you guys. Many of you know I got the engine in and tuned. I got the accelerator pedal mounted and connected. I got all the accessories reconnected. Power steering pump and replacement gear work like a champ. I got the kickdown installed and working so now when I am at full accelerator the lever is fully engaged. Rebuilt carb thanks to Duster Idiot works.
I did not drive it today because it looks like rain and I have not put the inspection plate back on yet.
Thank you everyone for the help. This was a helluva ride to get here. If you had told me 4 years ago I would doing what I am now I would have laughed and said your crazy. I have learned a ton and am loving every moment of it.
2006 Jeep Commander
2013 Chrysler 200
1964 Valiant 4 Door
1965 Plymouth Barracuda
1967 Chevy Camaro
PostPosted: Tue Jul 02, 2013 3:15 pm
Great!! There is nothing like the satisfaction of working through a project like this yourself and then driving the car around (or using whatever device it is that you built). You can have all the multimedia crap you want, or BUY anything you want, but it can't compare.
Enjoy, Lou
 Post subject: Smile
PostPosted: Tue Jul 02, 2013 3:23 pm
:D
Look forward to hearing how the test flight goes!
PostPosted: Tue Jul 02, 2013 4:39 pm
It could have gone better. i damaged my transmission cooling lines. So now I am replacing them.
2006 Jeep Commander
2013 Chrysler 200
1964 Valiant 4 Door
1967 Chevy Camaro
PostPosted: Tue Jul 02, 2013 8:03 pm
All right they are replaced now. Anyone know where you can find the temperature sender electrical connector?
2006 Jeep Commander
2013 Chrysler 200
1964 Valiant 4 Door
1967 Chevy Camaro
PostPosted: Thu Jul 04, 2013 10:13 am
If you're looking for the electrical connector that fits onto the little stud at the top of the sender, I'm pretty sure that's an 8-32 machine screw thread.
I see those little right angle push-on terminals occasionally, but couldn't find them on the web last night. I don't know the proper name for the little buggers, so my search wasn't very efficient.
A small ring terminal and a nut & lock washer would get it functional. Or you could use the female side of a "bullet" connector, like these. Get the smaller size (.157") might have to spread 'em a little.
I hope this helps, and good luck!
BC
'64 Dart GT convertible, 64 Dart 170 2-door post sedan in faded blue and rust (the Az Dart) & a sixty THREE Dart 170 2-door post sedan in faded blue and rust. (future project)
Early Dart Disorder (EDD) is real, and I've got it!
Users browsing this forum: DuckDuckGo [Bot], Google [Bot] and 6 guests
