| Valve Body / Shift Shaft Seal Replacement in vehicle https://slantsix.org/forum/viewtopic.php?t=52622 |
| Author: | Greg Ondayko [ Fri Jul 05, 2013 7:48 pm ] |
| Post subject: | Valve Body / Shift Shaft Seal Replacement in vehicle |
Hello, I recently Bought an original 24,000 Mile F body with a Leaky Shift shaft seal (the One the Operates the Gear Selector on the Valve body). Question is on a f body trans tunnel with a 904 trans and the Seal removal / install tool, can I replace this seal without Dropping / lowering the trans? I was curious if anyone has done this in the car without tilting the back of the trans down for access / clearance? Again, I have the tool for getting the old deal out and pressing in the new one. Thanks, Greg |
| Author: | Doc [ Mon Jul 08, 2013 10:01 am ] |
I do this seal change all the time... with a "home-made" tool, with no problem doing the work, under the vehicle. I do remove the rear cross member and lower (tilt) the engine / trans. assemble, for better access. DD |
| Author: | Greg Ondayko [ Mon Jul 08, 2013 5:30 pm ] |
Quote: I do this seal change all the time... with a "home-made" tool, with no problem doing the work, under the vehicle.
I do remove the rear cross member and lower (tilt) the engine / trans. assemble, for better access. DD Cool. That's what I thought i might have to do. Greg |
