| Mains clearence https://slantsix.org/forum/viewtopic.php?t=52632 |
| Author: | Eatkinson [ Sat Jul 06, 2013 7:26 pm ] |
| Post subject: | Mains clearence |
Confused by what the 63 FSM is stating. States desired clearance for the mains is .0005-.0015" in the Specs section under "Crankshaft Clearance Desired". This seems to make sense when I read it. Then, under 17. Checking the Connecting Rod Bearing Clearance (re-directed from 20.), it states "Desired clearance is .005-.0015". Checking crank clearance now using Plastigauge. Only torquing Main #1, per Doc's Twin #2 Rebuild article. I'm finding at spec torque that Main #1's clearance is .002", per the PG. I'm realizing now that of the three types of Plastigauge I could buy, I bought the mid-range that shows .002-.006, when that range is beyond the desired clearance the FSM requests. So, it would make sense to be on the 'low end' of what this PG can do, but won't give me an absolutely accurate reading because it's not designed to spread that thin. Correct? There's a minimal amount of taper I believe due to that I am not torquing the other mains: crank is just sitting in them. This all feels like splitting hairs and being way too dear: I'm just checking to make sure everything's in line. Advice please if what I see and diagnosed is what's happening, and I can move on? |
| Author: | CNC-Dude [ Sun Jul 07, 2013 12:43 am ] |
Yeah, its just a typo on the specs, most all engines, regardless of brand have nearly the same factory bearing clearance specs. However, you would never want to shoot for the low end of the tolerance range unless you have actual precision measuring equipment to verify your results. You probably need the next range down of plastigage to try to get a more accurate reading. Also, plastigage is less accurate if the crank isn't freshly reground, and it only shows the clearance at the exact spot where you place it, and doesn't show if the clearance is tapered or out of round, which it often can be and you would never know it without the use of a more precise way to measure. |
