| Exhaust manifold? https://slantsix.org/forum/viewtopic.php?t=52636 |
| Author: | Turbo Toad [ Sun Jul 07, 2013 9:44 am ] |
| Post subject: | Exhaust manifold? |
Is there any difference in exhaust manifolds? I have a 73 manifold that I'm looking at selling to a guy with a 87 d250, van and if there's some differences I don't want to waste his time or mine. Aaron |
| Author: | DusterIdiot [ Sun Jul 07, 2013 11:52 am ] |
| Post subject: | No, but... |
The manifold and choke pocket should be the same from 1973-up...there will be some casting rib variations...and sometimes there was core shift in the castings that shows up when the intake is bolted to it and the runners aren't all in a row (typically the remflex gasket takes care of the "short stove"). The pertinent issue is the 1987 truck, for that year the manifold has a cast in oxygen sensor bung if I remember correctly... So: If the truck is running on the ESC system still, he can use your manifold, but needs to weld in an O2 bung just below the flange on the exhaust pipe. If the truck is retrofitted with plain mopar EI or HEI, then your manifold is good to go. IMHO it's all good. You only need to worry about the 60's- pre 1972-ish manifolds that have the closed pocket or the open hole and cup style choke stove...then the fun really begins. -D.Idiot |
