| Main bearing clearance https://slantsix.org/forum/viewtopic.php?t=52642 |
| Author: | 63dartconv [ Sun Jul 07, 2013 5:13 pm ] |
| Post subject: | Main bearing clearance |
My mains are .002........is this ok? what should rod bearings be? |
| Author: | 63dartconv [ Sun Jul 07, 2013 5:48 pm ] |
#4 0.038 #3 0.038 #2 0.030 #1 0.002 |
| Author: | DusterIdiot [ Sun Jul 07, 2013 6:47 pm ] |
| Post subject: | Clearances... |
mains should be .0005 to .002 if forged crank... I would not want them to be on the edge of the loose side. rod bearings if a forged crank would be .0005 to .0025...again I would not want to be on the end of the loose goal post. |
| Author: | 63dartconv [ Sun Jul 07, 2013 7:57 pm ] |
Are my numbers to loose? |
| Author: | 63dartconv [ Sun Jul 07, 2013 9:56 pm ] |
Im such an idiot! 2 3 and 4 was in mm.....so actually 0.0015 |
| Author: | robertob [ Mon Jul 08, 2013 10:55 am ] |
See if you can switch around the non-thrust shells and get a different number. Do you have a ball-end micrometer (or a ball bearing of known diameter and a piece of vacuum hose)? Measure all the shell thicknesses, then measure the journals and the main bearing bores. Swap parts around to get the most even spread of clearances. I personally would be fine with those numbers if it is a used (not reground) crank. |
