| Choke Thermostat https://slantsix.org/forum/viewtopic.php?t=52645 |
| Author: | jhdeval [ Sun Jul 07, 2013 8:29 pm ] |
| Post subject: | Choke Thermostat |
So I have searched a few times and I can not seem to find a definite answer. I have a super six setup with a Carter BBD. Are the mechanical choke thermostats no longer available? If not what is a part number. Second if they are gone is the Carbsonly electronic conversion setup the other answer? |
| Author: | Reed [ Sun Jul 07, 2013 9:00 pm ] |
Carbs Only should be your first choice anyway since it is a better design than the original equipment. If you can't find a stock choke thermostat or a carbs only choke thermostat, there is always a manual choke. |
| Author: | DusterIdiot [ Sun Jul 07, 2013 9:04 pm ] |
| Post subject: | Yep... |
Quote: Are the mechanical choke thermostats no longer available?
They have been discontinued, and NOS is the only source. Per Reed, there is an electrical substitute that works better than stock, and manual is a cheap and easy install (I think I bought a kit at the local auto parts store for a whopping $10, knob, wire, and bracket for the dash.)-D.Idiot |
| Author: | Michael [ Sun Jul 07, 2013 9:14 pm ] |
I have a new factory unit that I do not need and will sell to you at cost. PM me if interested. |
| Author: | Springer [ Mon Jul 08, 2013 9:38 am ] |
I got a new one from RockAuto last winter. Works fine. |
| Author: | DusterIdiot [ Mon Jul 08, 2013 10:21 am ] |
| Post subject: | Interesting. |
Looks like Rock Auto has SMP CV230 on the list...for $15.97, but SMP's catalog no longer lists these...knowing that RockAuto does get old stock on an occasion, you might get lucky... -D.Idiot |
