| Turbo Torque Converter... https://slantsix.org/forum/viewtopic.php?t=52667 |
| Author: | RyGuyTooDry [ Mon Jul 08, 2013 8:49 pm ] |
| Post subject: | Turbo Torque Converter... |
Should I run the stock torque converter? It's a stock internal slant, super six, blow through 2300, around 12 psi. Drag strip car only. |
| Author: | robertob [ Wed Jul 10, 2013 10:30 am ] |
I have played with turbo cars, not slants, and usually you want to keep the stock converter. You can leave the line with almost full boost if you hold it against the converter, and usually a stock converter will slip enough to get you there. But it really depends on what turbo you are running - If you have a big turbo that needs revs to build boost then you want a converter that will 'flash' to a higher RPM before engaging. On the other hand, if you have a smallish turbo (if you are running only 12 psi, I think that qualifies) a loose converter will not let you build up enough engine torque and boost. I would run the stock one unless you can't get enough boost against it. |
| Author: | RyGuyTooDry [ Wed Jul 10, 2013 3:45 pm ] |
Thanks Rob, that's the answer I was hoping to hear actually! haha -Ryan |
