It is currently Fri Nov 20, 2026 12:10 am
PostPosted: Mon Jul 08, 2013 8:49 pm
Should I run the stock torque converter? It's a stock internal slant, super six, blow through 2300, around 12 psi. Drag strip car only.
1965 Plymouth Belvedere II Turbo Project - SOLD
2002 Subaru OBS
1995 Lexus LS400 Race Car
PostPosted: Wed Jul 10, 2013 10:30 am
Car Model: 1964 Valiant V200
I have played with turbo cars, not slants, and usually you want to keep the stock converter. You can leave the line with almost full boost if you hold it against the converter, and usually a stock converter will slip enough to get you there.
But it really depends on what turbo you are running - If you have a big turbo that needs revs to build boost then you want a converter that will 'flash' to a higher RPM before engaging. On the other hand, if you have a smallish turbo (if you are running only 12 psi, I think that qualifies) a loose converter will not let you build up enough engine torque and boost.
I would run the stock one unless you can't get enough boost against it.
PostPosted: Wed Jul 10, 2013 3:45 pm
Thanks Rob, that's the answer I was hoping to hear actually! haha
-Ryan
2002 Subaru OBS
