It is currently Thu Nov 19, 2026 8:07 pm
PostPosted: Tue Jul 16, 2013 8:35 am
Have 225 out of 65 coronet original 9 1/4".
Want to go to 10". Where can i purchase the reduced head bolts reference in Doc's article on clutches?
Will these work? http://www.summitracing.com/parts/arp-150-2201
Dave
86 Miser 170,000+
2 1/4" exhaust
Holley 1920 #55
HEI MSD BLaster 2
17.8 mpg
 Post subject: Maybe...
PostPosted: Tue Jul 16, 2013 9:24 am
The bolt head is much wider than the stepped head OEM bolt, so if you do, you will need to test fit and grind the bellhousing where the bolt heads contact the bell.
I'll see if I have an example of both in my junk and post a pic later.
PostPosted: Tue Jul 16, 2013 9:28 am
Thanks D.I. Look forward to the pics.
Dave
86 Miser 170,000+
2 1/4" exhaust
Holley 1920 #55
HEI MSD BLaster 2
17.8 mpg
 Post subject: Here...
PostPosted: Tue Jul 16, 2013 11:03 am
Stock stepped clutch cover bolt on the left form a 1981 Dodge with the 10" clutch and A-833OD.
On the right is the ARP Ford bolt that works great for the 9 1/4" cover,spec clutch cover, etc... heads and washers are a little bigger so you will need to check and clearance the bellhousing with a die grinder or dremel as these are in a tight location (3spd bellhousing is the worst in this scenario the 4 speed bell is a little more roomy).
tough to get a good close up but it should be obvious on the head size comparison.
Good Luck,
-D.idiot
PostPosted: Tue Jul 16, 2013 1:26 pm
How about just using some grade 8 Allen head bolts? Would they work?
Rick
PostPosted: Tue Jul 16, 2013 1:49 pm
I've heard of people using grade 8 bolts for the clutch cover, it probably wouldn't be too bad if the clutch were used for low rpm daily driving and no hard launches (the 10" clutch might come apart before the bolts). I notice that the OEM and ARP cluth bolts all have a smooth shank about 1/4" long to keep the bolt tolerence when torqued down (that allows the correct distance for the disc to operate without the cover being warped, which might happen if you used a fully threaded bolt when you tighten it down and the wrench doesn't "click"). So if using a grade 8, you might find a 1 1/4-1 1/2" bolt with a 1/2" of shank then use a threader to turn threads another 1/4" and trim off the end 1/2-3/4" of threads...
2 cents,
PostPosted: Wed Jul 17, 2013 6:25 am
I ordered 12 pt high strength bolts from McMaster.com.
PostPosted: Wed Jul 17, 2013 3:44 pm
Thanks everyone! I will look at McMaster Carr and see what they have.
Dave
86 Miser 170,000+
2 1/4" exhaust
Holley 1920 #55
HEI MSD BLaster 2
17.8 mpg
PostPosted: Wed Jul 17, 2013 7:49 pm
My local NAPA had the packaged 'Mr Gasket' brand clutch bolts for Ford, that's what I used. They look just like the ARP ones with the proper shank.
1966 Coronet Deluxe
 Post subject: Just make sure
PostPosted: Wed Jul 17, 2013 7:58 pm
PostPosted: Thu Jul 18, 2013 5:58 am
I use longer bolts on most apps. On my alum flywheels, I run a long bolt (1.25" or so) with a nut on the back, with Loctite.
PostPosted: Fri Jul 19, 2013 10:22 pm
I also did the 12 point high strength bolts from mcmaster. Worked great on the 10" diaphragm pressure plate.
PostPosted: Sat Jul 20, 2013 6:18 pm
Are these the correct ones from McMaster Carr?
http://www.mcmaster.com/#91271a589/=npl1ht
Dave
86 Miser 170,000+
2 1/4" exhaust
Holley 1920 #55
HEI MSD BLaster 2
17.8 mpg
 Post subject: Sort of...
PostPosted: Sat Jul 20, 2013 9:14 pm
That would work if the length was 1" not 1 3/4"...
PostPosted: Sun Jul 21, 2013 9:04 am
Cutting them down to 1" or 3/4" should work then correct?
Dave
86 Miser 170,000+
2 1/4" exhaust
Holley 1920 #55
HEI MSD BLaster 2
17.8 mpg
