| Honing Plate https://slantsix.org/forum/viewtopic.php?t=52755 |
| Author: | Dart270 [ Wed Jul 17, 2013 6:19 am ] |
Cool! Should work great. I have one in steel that is 2" thick - HEAVY. Lou |
| Author: | Junior [ Wed Jul 17, 2013 1:10 pm ] |
is aluminum strong enough to get the desired effect? |
| Author: | robertob [ Wed Jul 17, 2013 1:37 pm ] |
Should be. My machinist made one from Aluminum, not even as thick as this one. It just needs to give the headbolts something to torque against. |
| Author: | Pierre [ Wed Jul 17, 2013 3:21 pm ] |
Wouldn't steel be cheaper then the aluminum? Machining the aluminum would be easier and probably make up the difference. |
| Author: | hyper_pak [ Wed Jul 17, 2013 6:00 pm ] |
| Post subject: | Steel or Aluminum |
Well Bobby did make a steel one that I used to use. But I left it in the good care of one Sir Will of Glochester! So I took the other less travelled path and finished this aluminum one. Thanks Bobby! |
| Author: | Dart270 [ Thu Jul 18, 2013 5:55 am ] |
I am sure it is stiff enough to replicate the head stresses/strains. I have wondered if just running some bolts into the block with some individual washers/spacers wouldn't give you almost the same effect. Lou |
