| I (might) got this - exhaust and throttle mock ups https://slantsix.org/forum/viewtopic.php?t=52789 |
| Author: | Sprag [ Fri Jul 19, 2013 6:05 pm ] |
| Post subject: | I (might) got this - exhaust and throttle mock ups |
Well, this sure is easier to fit-up when you actually cut the pipe square. Now if I can only get my welds to not look like pigeon poop........ ![]() Sectioned from a 2 1/4" Dynomax mandrel 'J' bend, thought I should go bigger but that's the size I opened the manifold to. It think it should work. ![]() Made a throttle cable bracket for the Holley using an extra mopar cable clamp and a mystery throttle/kickdown bracket from the bone pile. The generic mopar cable clamp seats nicely in the notch and around the corner of the Holley base plate so I don't have to figure out my own tab(s) to control bracket pull/rotation. ![]() Mystery bracket gets welded to the hold down clamp then it gets chopped and tweaked. ![]() Not pretty but works perfect. I think I'll paint it.
| Author: | 64ragtop [ Sun Jul 21, 2013 11:15 pm ] |
Looks dang near perfect to me! Paint and shorten or darken that bright stud & call it DONE! BC |
