| what is the thread size in the center of the 225 crank? https://slantsix.org/forum/viewtopic.php?t=52799 |
Page 1 of 2 |
| Author: | USAJon [ Sat Jul 20, 2013 8:01 pm ] |
| Post subject: | what is the thread size in the center of the 225 crank? |
need to install a balancer/need to buy a bolt wondering what is that size ? |
| Author: | ceej [ Sat Jul 20, 2013 8:06 pm ] |
3/4 - 16 UNF |
| Author: | USAJon [ Sat Jul 20, 2013 8:17 pm ] |
thank u sir> |
| Author: | olafla [ Sun Jul 21, 2013 12:49 pm ] |
Same as V8. Olaf |
| Author: | NCDemon1971 [ Sun Jul 21, 2013 1:41 pm ] |
I put one from a bb Chrylser 400 in mine. |
| Author: | USAJon [ Mon Jul 22, 2013 8:29 am ] |
how's that working out ? |
| Author: | USAJon [ Mon Jul 22, 2013 8:33 am ] |
I can not find that bolt local any thoughts where I could purchase? |
| Author: | DusterIdiot [ Mon Jul 22, 2013 9:55 am ] |
| Post subject: | Junkyard or... |
Quote: any thoughts where I could purchase?
If you can't find a small or big block Mopar in a local junkyard, and you don't have a local fastener place, you'll be looking at McMaster-Carr or another online fastener place.-D.Idiot |
| Author: | olafla [ Mon Jul 22, 2013 4:23 pm ] |
The crankshaft vibration dampener bolt is 3/4"-16 UNF, 2.3 inches long, with a 1.5 inches minimum length threaded area. You will also need a thick washer, the washer is 1-15/16" x 1/4". summitracing.com: part number DCC-5249557AB Mopar Performance #P5249557AB - Mopar Performance Harmonic Balancer Bolts 3/4-16 x 2.250 inch (underhead) Olaf |
| Author: | Rick Covalt [ Mon Jul 22, 2013 4:44 pm ] |
I got mine at the local Hardware store. "Do it best Hardware" |
| Author: | robertob [ Mon Jul 22, 2013 6:00 pm ] |
edit: I see Olaf has the same info. |
| Author: | DusterIdiot [ Mon Jul 22, 2013 6:13 pm ] |
| Post subject: | Fyi... |
Quote: summitracing.com: part number DCC-5249557AB
This will not come up with the "AB"...Summit Lists it as DCC-5249557 at $9.97 FYI. |
| Author: | NCDemon1971 [ Mon Jul 22, 2013 7:08 pm ] |
Quote: how's that working out ?
Motor isn't together but it threaded into the crank no problem.
| Author: | olafla [ Tue Jul 23, 2013 7:47 pm ] |
Thank you DI, archive is updated! Olaf |
| Author: | USAJon [ Sat Aug 03, 2013 2:54 pm ] |
| Post subject: | Re: Fyi... |
| Page 1 of 2 | All times are UTC-08:00 |
