Head gasket sealer?
https://slantsix.org/forum/viewtopic.php?t=52813
Page 1 of 1
Author:  Eatkinson [ Sun Jul 21, 2013 8:01 pm ]
Post subject:  Head gasket sealer?
Is sealer necessary? Using a Corteco head gasket. Could be wrong, but from examination don't think it has any self-adhesive. It feels almost tacky on handling - maybe it doesn't need any? FSM states to use some: doesn't say one side or the other. Have read from others they use none. This gasket is sealing a milled head and decked 225, so they're surfaced, true and ready.
Author:  Dart270 [ Sun Jul 21, 2013 8:48 pm ]
No modern head gaskets I know need (or should have) sealer.
Author:  DusterIdiot [ Sun Jul 21, 2013 8:49 pm ]
Post subject:  Composite head gasket...
Nothing aftermarket is a shim style/OEM gasket. Felpro,Victor,Corteco are basically install and torque, no prep needed other than a clean mating surface.
Author:  ValiantBoyWonder [ Sun Jul 21, 2013 11:08 pm ]
Doc uses copper sealant on the spark plug lip side of the head (i believe).
Author:  Doc [ Mon Jul 22, 2013 10:42 am ]
Actually... I use a little high temp RTV along the outer lifter Gallery edge, just to prevent any oil "weeping" at that joint.
Author:  robertob [ Mon Jul 22, 2013 11:33 am ]
Both sides? All of the high-mileage slants I have owned weep right there, but the last one I rebuilt (with no sealer and a fel-pro gasket) never seeped in 50,000 miles of driving.
