| K Frame Weight https://slantsix.org/forum/viewtopic.php?t=52832 |
| Author: | Greg Ondayko [ Wed Jul 24, 2013 4:42 pm ] |
| Post subject: | K Frame Weight |
Hello Slanters, Does anyone know the Weight of a 67-72 A body K frame? Any engine configuration would be fine. I am looking for the weight without any mounts, rods, bushings etc. attached I have an earlyk frame from a 60-66 A Body and I weighed in at 28.4#.. I imagine the 67-72 models would be heavier.. Thanks for any info. Greg |
| Author: | slantzilla [ Thu Jul 25, 2013 12:01 am ] |
The late one is probably not a whole lot heavier, but if you look it over there is about 10 pounds you can cut off fairly easily. |
| Author: | Rob Simmons [ Thu Jul 25, 2013 4:09 am ] |
Just don't go TOO far with the cutting... Rightt Dennis? |
| Author: | slantzilla [ Thu Jul 25, 2013 11:03 am ] |
Actually that one I gave you needs welded around the flange and it's good to go. |
