It is currently Mon Nov 23, 2026 2:19 pm
PostPosted: Mon Jul 29, 2013 6:20 pm
Apparently I have a high lift cam in the used motor I bought and the adjustment screws on the #6 rockers are hitting my valve cover even with two cork gaskets. Which valve cover has the most clearance? The aftermarket ones I have found all indicate "stock height"
68 Barracuda Fastback \6, auto
64 Valiant hardtop \6, Hurst 4 Spd
63 Valiant Vert \6, Hurst 4 Spd
65 Dart GT \6, console auto
68 Chrysler Town and country 440 Auto
72 Swinger 318 AC/Discs
2010 Challenger R/T
2013 Dart Rallye
PostPosted: Mon Jul 29, 2013 7:39 pm
Shorten the adjustment screw on top................
PostPosted: Mon Jul 29, 2013 7:51 pm
What you really need is a set of Smith Bros pushrods of the proper length....shorter pushrods are indicated.
 Post subject: Yeah...
PostPosted: Mon Jul 29, 2013 8:45 pm
I'm trying to see how much lift you really have there, as I didn't have problems with valve cover clearance on running a .539 lift cam or the .550 lift cam I mocked up. Both worked perfectly fine and had lots of clearance using the stock late valve covers (70-80).
PostPosted: Mon Jul 29, 2013 10:40 pm
skelengerj,
The tallest valve cover I have found is the Spectre Chrome cover. You may want to make your own baffles though....when using this cover.
PostPosted: Tue Jul 30, 2013 5:58 pm
Thanks all for the replies. I would love to user a shorter adjustment screw, but these must be aftermarket rockers as they have an extremely large screw (it is a 7/16 x 20 hex head with a locking nut), seems to be custom order stuff.
I'm running a 1963 valve cover are the later years a little taller?
If I decide I need to shorten the push rods, what is the best way to determine the length required?
2010 Challenger R/T
2013 Dart Rallye
