It is currently Fri Nov 20, 2026 6:52 pm
PostPosted: Fri Aug 23, 2013 4:42 pm
Can someone help me out here? Click the photo for a full-size image.
PostPosted: Fri Aug 23, 2013 5:29 pm
Heater Hose Fitting(?) :shock:
for a 5/8"hose.
not sure of the thread count, but someone here knows!
1964 Dart GT
PostPosted: Fri Aug 23, 2013 6:32 pm
6 Pack Dart
I think it's a pipe thread.
Richard
Thanks. Stopped into a local auto supply and they pointed me to the right one: common I guess. You're right: it's called a "Heater Hose Fitting", and unless I totally missed it, the FSM and parts book doesn't even mention it. For a 5/8 hose and it's 1 5/8"L, 3/8" NPT thread.
PostPosted: Fri Aug 23, 2013 11:52 pm
Finding the replacement is easy - getting the old one out whole so that you may fit the replacement may make you wish you would have just left it there as is.
PostPosted: Sat Aug 24, 2013 6:17 am
I see a can of PB Blast in the picture! :lol: It should come right out Pierre. :shock:
1964 Dart GT
PostPosted: Sat Aug 24, 2013 7:24 am
Last I remember looking at those things at parts stores, they were steel / iron just like the head, not brass like most other fittings. I was thinking about replacing mine because it looked pretty crummy when I was going through the motor but realized the old one still sealed so I left well enough alone. If you are going to replace it, do yourself a favor and find a brass one.
Check here.
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 7 guests
