It is currently Mon Nov 23, 2026 7:55 am
 Post subject: oil pump o rings
PostPosted: Thu Aug 01, 2013 7:14 am
for slant six oil pumps,,,anyone know of a source for the large o ring that goes under the rotor cap and the sealing washer for the pressure relief plug?
thanks
 Post subject: They are..
PostPosted: Thu Aug 01, 2013 7:16 am
Included in the Felpro Master Gasket set for an engine rebuild, I'd bet with some looking around the Fel-Pro catalog might have them listed.
PostPosted: Thu Aug 01, 2013 7:46 am
I did find the oil pump pressure relief plug seal,, Fel Pro fpg 3122
 Post subject: If....
PostPosted: Thu Aug 01, 2013 9:43 am
If you can't find the cover gasket/large "o" ring, let me know i might have one from a spare engine rebuild kit that i could throw in an envelope 'fer ya!
PostPosted: Thu Aug 01, 2013 5:56 pm
Is Fel-Pro 13338 the one you're looking for?
http://www.summitracing.com/parts/fel-1 ... e/chrysler
Olaf
Aspenized
PostPosted: Fri Aug 02, 2013 5:11 am
thanks :) ,, right now I am just rounding up some part numbers....
Fel-Pro 13338
bingo :) ,, that is the correct o ring,,,
