Hello newbee 1981 SL6 hydrulic motor questions
https://slantsix.org/forum/viewtopic.php?t=52923
Page 1 of 1
Author:  rustytoolss [ Thu Aug 01, 2013 5:59 pm ]
Post subject:  Hello newbee 1981 SL6 hydrulic motor questions
I'm interested in knowing if the 1981up 225's with the hydraulic cams were a good choice for a daily driver ride ? outside of no valve adjustment, were there any power/mileage benefits ?
My prime intrest is in mileage. And ways to improve mileage. Whats good/whats not. Although I would be interested in the super six 2brl system.
Did some years/heads etc work better than others?
And here's a long shot.....I'm looking to buy a Dodge A100 pickup (SL6/ or small block)with a automatic.... anyone able to help with that ?
Good to be here. Shawn
Clinton, Ohio
Author:  Reed [ Thu Aug 01, 2013 6:23 pm ]
The stock hydraulic camshaft profile is fairly tame. However, it does OK if you mill the head to increase the dynamic compression ratio to around 8:1.
The only advice I would give about selecting a head for fuel economy purposes would be to get a post 72 or at the least a post 67 head. Post 72 heads have hardened exhuast valve seats for unleaded gas and post 67 heads have a revised combustion chamber for better combustion.
If you are wanting to put together a slant six automatic drivetrain to go in an A100 for maximum fuel economy, I would say get an 80s era engine and transmission out of a truck or van. Mill the head to get the dynamic compression up to around 8:1, install an HEI ignition system and spend the time to custom curve your timing advance, run 3.2 or even 3.5 rear axle gears, install a vacuum gauge and drive to maximize engine vacuum, keep the single barrel carburetor and run a Holley 1920 Economizer if you can find one in god shape. Build for economy in a truck or van means building for maximum torque at low RPM. Much of what you read about hot-rodding an engine won't apply. Smaller valve to increase port velocity, smaller carb as well.
When the time comes to set up the truck or van, fabricate and install a true cold air intake system. This will likely mean running the air offset cleaner off of a 80s era van so it will clear the doghouse, but you do not want to run either an open element or one of the 60s era air cleaners since they will suck the hot air out of the engine compartment and decrease performance and economy.
Run a 195 degree thermostat and 5W-30 oil, synthetic if you can afford it.
Good luck and keep us posted!
Author:  rustytoolss [ Thu Aug 01, 2013 8:01 pm ]
Thanks for the input. I was thinking that a 2.94 rear ratio might be a good choice / but around town it would kill mileage. On the highway might be good. But the 3.23 would probably be the best overall.
Author:  Reed [ Thu Aug 01, 2013 9:24 pm ]
In a light A series van or pickup that doesn't haul anything, yeah, 3.2 would probably be best.
