It is currently Mon Nov 23, 2026 4:04 am
PostPosted: Fri Aug 02, 2013 9:12 pm
Car Model: 1963 Dodge Dart convertible
Hey follks, I know I have seen it here but cant seem to locate the thread for recommended spark plug for the late model heads, I have a head off of an 83 van.
Thanks.
John
Psychics will soon lead dogs to your body!
1963 Dodge Dart 270 convertible
 Post subject: Only one...
PostPosted: Fri Aug 02, 2013 9:16 pm
You only have one plug available:
NGK UR-5
If you need hotter UR-4, colder for UR-6.
I found on my hipo engine builds that UR-5 was too cold, and UR-4 was too hot and ended up with AC Delco R-45TS gapped at .040 as being 'just right' for some reason.
We do not have a readily available extended tip plug like the drool tube heads guys have, so you are stuck with the above options.
Good Luck,
PostPosted: Fri Aug 02, 2013 9:26 pm
Thanks DI.
John
Users browsing this forum: Amazon [Bot] and 9 guests
