Recommended spark plugs for late model head
https://slantsix.org/forum/viewtopic.php?t=52935
Author:  hideogumperjr [ Fri Aug 02, 2013 9:12 pm ]
Post subject:  Recommended spark plugs for late model head
Hey follks, I know I have seen it here but cant seem to locate the thread for recommended spark plug for the late model heads, I have a head off of an 83 van.
Thanks.
John
Author:  DusterIdiot [ Fri Aug 02, 2013 9:16 pm ]
Post subject:  Only one...
You only have one plug available:
NGK UR-5
If you need hotter UR-4, colder for UR-6.
I found on my hipo engine builds that UR-5 was too cold, and UR-4 was too hot and ended up with AC Delco R-45TS gapped at .040 as being 'just right' for some reason.
We do not have a readily available extended tip plug like the drool tube heads guys have, so you are stuck with the above options.
Good Luck,
Author:  hideogumperjr [ Fri Aug 02, 2013 9:26 pm ]
Thanks DI.
John
