| Carb Spacer https://slantsix.org/forum/viewtopic.php?t=52963 |
Page 1 of 3 |
| Author: | slant2340 [ Tue Aug 06, 2013 8:18 am ] |
| Post subject: | Carb Spacer |
Anyone find a benefit to running a carb spacer? Currently have a Clifford intake with a Carter AVS off a 273. I have a 1" & 2" HVH Super Sucker spacers available to try. I know they work great on V8's just not sure the SL6 will respond the same. I'm thinking it will give it better fuel atomization and maybe giving it a little more plenum volume might help on a combination strictly being used a bracket race car. |
| Author: | DusterIdiot [ Tue Aug 06, 2013 8:23 am ] |
| Post subject: | Room under the hood. |
The taller versions work pretty good on the clifford intake, but the room under the hood of an A-body is limited due to the hood so you may note be able to get the 2" in there without a drop air cleaner. I know of one Dodge Truck in Oregon that uses a 4" spacer and it increased the low end torque and overall driveability of the slant in the heavy vehicle. -D.Idiot |
| Author: | slant2340 [ Tue Aug 06, 2013 9:01 am ] |
| Post subject: | Re: Room under the hood. |
Yeah there is limited space under the A-Body hood but i do have a drop base air cleaner on it right now and a couple others i can try. Torque is definitely what i'm after to improve. |
| Author: | slantzilla [ Fri Aug 09, 2013 10:32 am ] |
On one of my early combinations I tried a 1" 4 hole spacer on a Clifford intake with a 390 Holley. It was worth a tenth in the 1/4 mile. |
| Author: | Greg Ondayko [ Fri Aug 09, 2013 7:21 pm ] |
that is on the list of expierements I want to try on ruster drag car project. I have to modify the hood or cut some scoop onto there to do this project. I have the same one Dennis describes. Gary Bruner in TN. has a pretty tall 2 or 2.5 spacer on his Clifford manifold. he runs high 12s or low 11s in that car. good luck. Greg |
| Author: | Greg Ondayko [ Mon Aug 26, 2013 10:17 am ] |
I tried the 1" spacer on ruster this weekend and did not see any clear advantage. It was running mid 12.20s as it usually does in that weather. I Might have to try a 2" or more spacer. And thhat might require some hood modifications. Greg |
| Author: | CNC-Dude [ Mon Aug 26, 2013 10:37 am ] |
Were you using a 4 hole spacer or open. The HVH spacers mentioned above are a solid 68 HP gain and a mild SBC.....I know them pretty well there, the next time your in K'ville i'll see if I can arrange a private tour. |
| Author: | Greg Ondayko [ Mon Aug 26, 2013 11:24 am ] |
Quote: Were you using a 4 hole spacer or open. The HVH spacers mentioned above are a solid 68 HP gain and a mild SBC.....I know them pretty well there, the next time your in K'ville i'll see if I can arrange a private tour.
It was a 4 hole.The clifford Carb Adapter I have is a 4 hole so I think I would need to cut or modify the center section out of the clifford adapter to get the open one to work correctly or am I mistaken here? Greg |
| Author: | Greg Ondayko [ Mon Aug 26, 2013 11:38 am ] |
Here are the HVH quick fuel selections for a 4150 squarebore carb base as I have. http://www.summitracing.com/search/bran ... h%20spacer What do you sages suggest; as I was less then impressed with the No name aluminum 1" four hole spacer that I had tried Thanks, Greg |
| Author: | Kidd [ Mon Aug 26, 2013 8:43 pm ] |
I run a 2 inch spacer under my QF carb on my drag car.With a drop base, I can run a 2 inch K/N aircleaner.I also have a fiberglass hood on my 62 Valiant w/ no scoop.....and it fits. I KNOW my car is slower without it. |
| Author: | CNC-Dude [ Tue Aug 27, 2013 9:53 am ] |
When the HVH spacers first came out about 9 years ago they were only available in the 2" thick size, and thus the 68 HP claims. A standard 1" thick design spacer might not always provide a noticeable increase in all situations. But I did design and manufacture a set of 1" spacers for a while that were a 2 hole design for the vintage carb 2 BBL market that when used as a 3 x 2 setup, showed a 15 HP gain. |
| Author: | emsvitil [ Tue Aug 27, 2013 3:40 pm ] |
Quote: When the HVH spacers first came out about 9 years ago they were only available in the 2" thick size, and thus the 68 HP claims. A standard 1" thick design spacer might not always provide a noticeable increase in all situations. But I did design and manufacture a set of 1" spacers for a while that were a 2 hole design for the vintage carb 2 BBL market that when used as a 3 x 2 setup, showed a 15 HP gain.
So with a 1" spacer under a BBS I should get 7.5 HP......... |
| Author: | CNC-Dude [ Tue Aug 27, 2013 8:59 pm ] |
Well maybe not with your garden variety spacer, but with mine I would say that is reasonable to expect. |
| Author: | Kidd [ Wed Aug 28, 2013 4:00 pm ] |
Forgot to mention, Mine is a Moroso non metallic open design. |
| Author: | Rick Covalt [ Wed Aug 28, 2013 5:24 pm ] |
Quote: What do you sages suggest;
I suggest that $127 is too much for a carb spacer!! Wow, I am in the wrong business.Rick Yeah, yeah,I know. Speed cost money, how fast do you want to go! |
| Page 1 of 3 | All times are UTC-07:00 |
