It is currently Sun Nov 22, 2026 3:20 pm
 Post subject: throttle return spring ?
PostPosted: Thu Aug 08, 2013 7:25 pm
the holley 2280 that I am using has a throttle return spring coiled around the throttle shaft. Is that considered to be sufficient or is it recommended to have a second, back up throttle return spring?
PostPosted: Thu Aug 08, 2013 7:39 pm
6 Pack Dart
Use a second spring for safty sake.
Richard
 Post subject: Yep...
PostPosted: Thu Aug 08, 2013 7:55 pm
As Fopar said, mopar also used a regular spring as the primary, the carb's have the spring on the throttle shaft as a back up in case the regular spring fails. (similar to the setup on the late Holley 1945's).
PostPosted: Fri Aug 09, 2013 3:42 am
In PA you would fail state safety inspection without two throttle return springs
PostPosted: Fri Aug 09, 2013 5:08 am
got it,, the spring on the shaft is the back up,, I should install a second one with a bit more tension on it..
thanks
Users browsing this forum: Google [Bot] and 16 guests
