| temperature sending switch https://slantsix.org/forum/viewtopic.php?t=52986 |
| Author: | 63dartgt [ Thu Aug 08, 2013 12:35 pm ] |
| Post subject: | temperature sending switch |
ok I have several 65 an earlier heads got got a tricked out head that's an 83 there are 2 3/8s 18 threads on top no 1/8th pipe thread what can I do that would match well an accurately with my 63 gauge it and would the use of an adapter hold it out of the water/coolant side note does anyone no what the est piston deck clearance is with K1 rods and pistons for my plans of a future project |
| Author: | DusterIdiot [ Thu Aug 08, 2013 12:43 pm ] |
| Post subject: | Threaded Bungs |
Quote: got a tricked out head that's an 83 there are 2 3/8s 18 threads on top no 1/8th pipe thread what can I do that would match well an accurately with my 63 gauge
You buy a bushing and insert your temp sensor there, or you can use the 1980's temp sensor as the resistance isn't much different than the 1960's sensor.
| Author: | 63dartgt [ Thu Aug 08, 2013 12:46 pm ] |
having trouble finding a 82+ temperature sender switch |
| Author: | Reed [ Thu Aug 08, 2013 1:03 pm ] |
STANDARD MOTOR PRODUCTS Part # TS17T - WITH LIGHT AIRTEX / WELLS Part # 1T1010 w/ Gauge |
