| Holley vacuum port layout https://slantsix.org/forum/viewtopic.php?t=52993 |
| Author: | itlldo1 [ Thu Aug 08, 2013 6:03 pm ] |
| Post subject: | Holley vacuum port layout |
Does anyone have a diagram showing the vacuum port layout for a 2280? I found one model that has no idle adjusment screws-they're sealed. There are two small ports on each side of the front of the carb outboard of where the idle mixture screws would be, a larger one in the center front base (charcoal cannister?), and two large ones in the rear which I'm assuming is for a PCV and vacuum brake booster. Does it matter which one is used for the PCV hose? The choke pulloff is t'd from a port on the rear of the carb. Where does this other line go to? Is there a ported vacuum on the 2280? Thks. Mike |
| Author: | Reed [ Thu Aug 08, 2013 7:17 pm ] |
The search button is your friend. CLICK ME. |
