| throttle return spring ? https://slantsix.org/forum/viewtopic.php?t=52995 |
| Author: | DadTruck [ Thu Aug 08, 2013 7:25 pm ] |
| Post subject: | throttle return spring ? |
the holley 2280 that I am using has a throttle return spring coiled around the throttle shaft. Is that considered to be sufficient or is it recommended to have a second, back up throttle return spring? |
| Author: | Fopar [ Thu Aug 08, 2013 7:39 pm ] |
Use a second spring for safty sake. Richard |
| Author: | DusterIdiot [ Thu Aug 08, 2013 7:55 pm ] |
| Post subject: | Yep... |
Quote: Is that considered to be sufficient or is it recommended to have a second, back up throttle return spring?
As Fopar said, mopar also used a regular spring as the primary, the carb's have the spring on the throttle shaft as a back up in case the regular spring fails. (similar to the setup on the late Holley 1945's).-D.Idiot |
| Author: | 70valiant [ Fri Aug 09, 2013 3:42 am ] |
In PA you would fail state safety inspection without two throttle return springs |
| Author: | DadTruck [ Fri Aug 09, 2013 5:08 am ] |
Quote: carb's have the spring on the throttle shaft as a back up
got it,, the spring on the shaft is the back up,, I should install a second one with a bit more tension on it..thanks |
