It is currently Sat Nov 21, 2026 6:35 pm
 Post subject: Length of main cap bolts
PostPosted: Tue Aug 13, 2013 5:08 pm
Does anyone know what the length is of the main cap bolts from the underside of the head to the end? While at the Nationals I picked up a set of main cap bolts for use with a windage tray - the seller said they came off of a slant with a windage tray. Wondering if they just aren't LA main cap bolts.
47 Dodge Custom 4 Door sedan
87 D100 Short Bed slant 6
Retired USAF 1966-1986
PostPosted: Tue Aug 13, 2013 5:21 pm
The Slant 6 windage package bolts were V-8 bolts and had to have a hardened washer added to them to shorten them up a bit. At least that is what I rememeber.
Rick
PostPosted: Tue Aug 13, 2013 6:54 pm
6 Pack Dart
They are 2 3/4"
Richard
PostPosted: Wed Aug 14, 2013 9:04 am
Be careful when using the LA "tower bolts" in a SL6.
They are longer and can restrict oil flow to the crank, if the washers are not used. ( or the bolt are not shortened)
These bolts do not have the same thread length so the thread can bottom-out and come-up to torque... but not "clamp" the main caps down as intended.
Users browsing this forum: Ahrefs [Bot], Amazon [Bot], Bing [Bot], DuckDuckGo [Bot], Google [Bot] and 4 guests
