Length of main cap bolts
https://slantsix.org/forum/viewtopic.php?t=53045
Author:  65 dartman [ Tue Aug 13, 2013 5:08 pm ]
Post subject:  Length of main cap bolts
Does anyone know what the length is of the main cap bolts from the underside of the head to the end? While at the Nationals I picked up a set of main cap bolts for use with a windage tray - the seller said they came off of a slant with a windage tray. Wondering if they just aren't LA main cap bolts.
Author:  Rick Covalt [ Tue Aug 13, 2013 5:21 pm ]
The Slant 6 windage package bolts were V-8 bolts and had to have a hardened washer added to them to shorten them up a bit. At least that is what I rememeber.
Rick
Author:  Fopar [ Tue Aug 13, 2013 6:54 pm ]
They are 2 3/4"
Richard
Author:  Doc [ Wed Aug 14, 2013 9:04 am ]
Be careful when using the LA "tower bolts" in a SL6.
They are longer and can restrict oil flow to the crank, if the washers are not used. ( or the bolt are not shortened)
These bolts do not have the same thread length so the thread can bottom-out and come-up to torque... but not "clamp" the main caps down as intended.
