It is currently Sat Nov 21, 2026 11:30 am
PostPosted: Wed Aug 14, 2013 4:51 am
I know its a bit of a broad subject, but wasnt quite sure what to title it.
I started small, but the project (as they tend to do), has grown. I have an Aussie Chrysler Valiant, with a 225 slant.
I have aquired a head, with hardened valve seats, oversized SS valves, some mild port work and will be putting in some beefier vavle springs.
The car already has an alloy longrunner manifold, and a 4bbl holley carb, extractors and electronic ignition
I have a Cam of the following spec
Advertised
- Inlet opens 35 closes 76
- Exhaust opens 75 closes 35
Duration 282 - 290
@ .050"
- Inlet opens 11 closes 43
- Exhaust opens 52 closes 12
Duration 234 - 243
PostPosted: Wed Aug 14, 2013 4:55 am
aaargh, it chopped off half my post!
I dont want to start throwing money at it hand over fist, but I want to keep the slant in it, and get some performance (nothing crazy)
The car has original 70,000 miles (genuine one little old lady owner car), and as I will be taking the motor out to put the cam in and replace gaskets, what else should I be doing?
I would imagine new piston rings, but should I need maybe some higher compression pistons? Anything else that I should be doing whilst I am in there?
 Post subject: Uh huh...
PostPosted: Wed Aug 14, 2013 7:36 am
Duration 234 - 243
That duration @ .050 you are looking at a 10:1 SCR mill, time to pull the engine, take some measurements and get ready to cut some meat off the deck and head to acheive it.
PostPosted: Wed Aug 14, 2013 7:28 pm
Thanks for that, I just picked up the head now, and when the engine is apart, I will measure the gap at the top of the piston at TDC and then work out how much to deck.. 10:1 should be find do you think?
 Post subject: Yeah...
PostPosted: Wed Aug 14, 2013 8:52 pm
230@ .050 will like the 10:1...if it's 240@50 it's going to want more...especially if the LSA narrow...
Users browsing this forum: Bing [Bot], Google [Bot] and 6 guests
