| Re-use carb flange gasket? https://slantsix.org/forum/viewtopic.php?t=53053 |
| Author: | Sean Mallory [ Wed Aug 14, 2013 12:59 pm ] |
| Post subject: | Re-use carb flange gasket? |
I've got a few laying around that were only used for a matter of days. Still you can see the outline of the carb bottom. Some are a rubberish material and others are paperish. I want to try a different carb as an experiment. And what is the preferable gasket for the 1945? |
| Author: | Sean Mallory [ Thu Aug 15, 2013 6:27 am ] |
lol...no luv for the newbee? stupid question I guess never reuse any gasket methinks |
| Author: | duval67 [ Thu Aug 15, 2013 6:28 am ] |
I've reused a base gasket before when taking the carb off to clean it and such. Never after an extended period of time though. Might as well try--not a big deal if it doesn't work. |
| Author: | Sean Mallory [ Thu Aug 15, 2013 6:56 am ] |
Yea I'll reuse one for my experiment. I can't seem to get rid of an off idle glitch so I am trying another carb to see if it has any affect. Starting to think the distributor needs work, but this test may firm up that notion more. |
| Author: | kielbasa [ Thu Aug 15, 2013 11:49 am ] |
I coat my gasket in grease or anti seize so when you pull off the carb it doesn't ruin gasket. I do it with all sorts of cars especially vws with ported gaskets.. no probs. |
| Author: | pishta [ Sun Aug 18, 2013 4:37 pm ] |
sure. If you are scared, soak it in gas for a few minutes. then install. I reused head gaskets before with no ill effects. I was POOR back then but its hardly worth it today. |
| Author: | Sean Mallory [ Sun Aug 18, 2013 4:43 pm ] |
thanks, I used to be poor too... has nothing to do with happiness, that I am sure of! |
