It is currently Thu Jun 18, 2026 8:14 pm
 Post subject: Rod bolts
PostPosted: Thu Sep 26, 2013 10:09 pm
Is it normal for the rod bolts to fall out of the rods on a 170?
Just one of the mysteries of this block. First I though it was a 225 block, I was told that it was by person that I got it from and they are usually reliable.
Then I noticed the crank didn't look quite right. Then I noticed the pistons were at the top of the bore when removing them. It also looks like it munched a distributor gear some time in the past.
I have most of the parts for a short block. But what am I going to do with a 170...
PostPosted: Thu Sep 26, 2013 11:12 pm
6 Pack Dart
How long was the water pump to head hose?
How long are the rods (center of small end to center of big end)?
Richard
PostPosted: Fri Sep 27, 2013 12:16 am
To answer the original question, it is not unusual for rod bolts to fall out of stock, used rods, no matter what CID.
Users browsing this forum: Google [Bot] and 9 guests
