| Oil Filter Attaching Stub Tube https://slantsix.org/forum/viewtopic.php?t=53093 |
| Author: | rgmcmanus [ Tue Aug 20, 2013 9:21 am ] |
| Post subject: | Oil Filter Attaching Stub Tube |
When I was changing the oil and filter on my new (rebuilt) 225, I noticed the Oil Filter Attaching Stub didn't have a Tube like my old 1963 225 had. Is this a problem? |
| Author: | DusterIdiot [ Tue Aug 20, 2013 9:35 am ] |
| Post subject: | No, but... |
No it's not a problem, but the tube would have been nice to prevent drainback of the oil if it was a concern. You can still change your stub for a tube (pull off your old oil pump or find one at a junkyard. The work around is Wix 1806 that has an anti-drain back mechanism in the filter itself so you can keep you stub and not need the tube. FYI. -D.Idiot |
| Author: | rgmcmanus [ Thu Aug 22, 2013 11:11 am ] |
The Summit Racing website says the Fram PH8A has the anti-drain back mechanism, also. |
| Author: | Eatkinson [ Thu Aug 22, 2013 12:30 pm ] |
Fortuitously-timed question - I just was wondering if I needed to swap out my taller stand tube from my '63 225 for the stub on the new Melling I installed. I'll be doing that now. Thanks for asking this question. |
| Author: | DusterIdiot [ Thu Aug 22, 2013 12:34 pm ] |
| Post subject: | Lol... |
Quote: Fram PH8A
It also produces new clean oil and with every sale of 1,000,000 filters you get the deed to a bridge in Arizona that was for sale... |
| Author: | Aggressive Ted [ Thu Aug 22, 2013 1:55 pm ] |
Good one DI! |
| Author: | Danarchy [ Thu Aug 22, 2013 1:57 pm ] |
Use WIX Filters. Don't ever use FRAM. WIX 51515 or WIX 51806 (if you don't have a stand pipe) |
| Author: | Pierre [ Thu Aug 22, 2013 4:15 pm ] |
To be nitpicky - wix 51806, 1806 is the napa number. I'd rather use the 51806 instead of the original standpipe. The check valve in the standpipe is pretty restrictive looking. |
