Help with Exhaust manifold stud
https://slantsix.org/forum/viewtopic.php?t=53104
Page 1 of 1
Author:  Eatkinson [ Wed Aug 21, 2013 12:57 am ]
Post subject:  Help with Exhaust manifold stud
I bought a rebuilt head from Doc and was installing my exhaust and intake manifolds tonight.
Kept trying to install the nut/brass ring combo on the first exhaust manifold stud on top, next to the water elbow outlet. The flex nut just doesn't want to thread on.
What's a good way to fix the situation without having to take everything apart and remove/replace the stud?
I think it's the end, which looks a mite 'unthreaded', and is causing the flex nut not to catch. Pressing on the nut as I turn doesn't seem to do any good. Any advice about what to do would be wlecomed, thanks.
Author:  duval67 [ Wed Aug 21, 2013 2:40 am ]
Do you have a tap and die set? You could run that down the stud and make sure the threads are good. Or you could try a different nut first and see if it catches and chases the threads.
Author:  emsvitil [ Wed Aug 21, 2013 3:15 am ]
Dremel the last 1 or 2 threads off.
Then if you don't have a die, use a steel nut to straighten/fix the threads.
Author:  Aggressive Ted [ Wed Aug 21, 2013 3:09 pm ]
Taper the end on a 45 with a flat file to remove some of the threads and the nut will go right on......takes about two or three minutes.
Author:  ValiantBoyWonder [ Wed Aug 21, 2013 6:06 pm ]
I dont think that nut fits on there. I've noticed a few heads that have a different stud for that end one. Does the nut fit on to the other studs?
Author:  wjajr [ Thu Aug 22, 2013 5:17 am ]
Manifold installation tip:
Always test fit of all nuts on studs before attempting to mount manifolds. Generally the buggered stud will always be the one with poorest access; Murphy ’s Law.
Author:  Eatkinson [ Thu Aug 22, 2013 12:29 pm ]
Thanks all, and AT - your recommendation to file the stud (don't know why I didn't think to do that) worked great.
Only thing I don't like is this stud appears shorter than the others, so now the nut is threaded on, but only 1/2 of the stud is through the nut, and I have a feeling I'm close to spec on it's tightness - we'll see.
Oh well, I'm not changing it out unless i have a problem.
Author:  Aggressive Ted [ Thu Aug 22, 2013 1:57 pm ]
If you do....I always use longer studs. Especially when using a RemFlex gasket. They are much thicker. I toss the stock studs.
Author:  Eatkinson [ Thu Aug 22, 2013 5:48 pm ]
Oh, didn't even think of that. That's why.
Author:  pishta [ Sat Aug 24, 2013 5:00 pm ]
Torque spec is like 15 inch lbs. Doubt you are gonna strip it out.
