factory brown wire ?
https://slantsix.org/forum/viewtopic.php?t=53105
Page 1 of 1
Author:  USAJon [ Wed Aug 21, 2013 8:12 am ]
Post subject:  factory brown wire ?
OK
re-installing the wires on the passenger side/while I had marked them one paper/taped marking has fallen off and been lost. it looks to be a factory end say 12 gage? brown wire marked 2771 363 96555 W.
I'm lost as where it goes..
coil ?
Author:  Sam Powell [ Fri Aug 23, 2013 7:01 am ]
Is this dash, engine or body harness? One end must be connected somewhere. Where?
Sam
Author:  Rick Covalt [ Fri Aug 23, 2013 3:40 pm ]
http://www.mymopar.com/index.php?pid=24
Wiring diagrams here.
Heavy brown may be to starter relay? Guessing
Rick
Author:  USAJon [ Fri Aug 23, 2013 4:44 pm ]
rick that's a great listing of wires.
it was on the dist side. went to the starter relay
looks 2b the netural safty switch which I remember I did not mark.
I have a trans act valve body so I guess I cn just tape it off ?
Author:  Rick Covalt [ Fri Aug 23, 2013 5:15 pm ]
Great! A couple months till Mason Dixon! Hope you can make it!
Rick
Author:  USAJon [ Fri Aug 23, 2013 6:09 pm ]
yep!
me 2.
Author:  Sam Powell [ Fri Aug 23, 2013 7:39 pm ]
You will need to ground the starter relay tab for the neutral safety switch for the starter relay to work.
Sam
Author:  USAJon [ Mon Aug 26, 2013 4:13 pm ]
I'm just going to hook it up.
