| Cylinder head hose fitting - specs? https://slantsix.org/forum/viewtopic.php?t=53139 |
| Author: | Eatkinson [ Fri Aug 23, 2013 4:42 pm ] |
| Post subject: | Cylinder head hose fitting - specs? |
Can someone help me out here? Click the photo for a full-size image.
| Author: | Danarchy [ Fri Aug 23, 2013 5:29 pm ] |
Heater Hose Fitting(?) for a 5/8"hose. not sure of the thread count, but someone here knows! |
| Author: | Fopar [ Fri Aug 23, 2013 6:32 pm ] |
I think it's a pipe thread. Richard |
| Author: | Eatkinson [ Fri Aug 23, 2013 6:32 pm ] |
Thanks. Stopped into a local auto supply and they pointed me to the right one: common I guess. You're right: it's called a "Heater Hose Fitting", and unless I totally missed it, the FSM and parts book doesn't even mention it. For a 5/8 hose and it's 1 5/8"L, 3/8" NPT thread. |
| Author: | Pierre [ Fri Aug 23, 2013 11:52 pm ] |
Finding the replacement is easy - getting the old one out whole so that you may fit the replacement may make you wish you would have just left it there as is. |
| Author: | Danarchy [ Sat Aug 24, 2013 6:17 am ] |
I see a can of PB Blast in the picture! |
| Author: | Pierre [ Sat Aug 24, 2013 7:24 am ] |
Last I remember looking at those things at parts stores, they were steel / iron just like the head, not brass like most other fittings. I was thinking about replacing mine because it looked pretty crummy when I was going through the motor but realized the old one still sealed so I left well enough alone. If you are going to replace it, do yourself a favor and find a brass one. Check here. |
