| I need to find this pipe tap - who has an idea? https://slantsix.org/forum/viewtopic.php?t=53147 |
| Author: | Eatkinson [ Sun Aug 25, 2013 12:30 pm ] |
| Post subject: | I need to find this pipe tap - who has an idea? |
Any good ideas what type of store might stock an 1/4-18 NPTF tap that I could locally try to source today (in LA)? I'm informed I need NPTF over NPT. I'm drilling/tapping the temp sensor outlet in my '69 head for the larger 1/4-18 NPTF threads that '63 used. I have a good temp sensor and need to re-use it. The usual suspects (Home Depot, Sears, Anawalt/True Value) have all failed me and I'd rather do this when the engine's on the stand, not in the car (which means I have to find it today - the engine is going back in today). Anyone have ideas? |
| Author: | slantzilla [ Sun Aug 25, 2013 1:49 pm ] |
http://www.mcmaster.com/#pipe-taps/=o8093u They aren't cheap, but if they haven't got it, you don't need it. |
| Author: | Pierre [ Sun Aug 25, 2013 7:09 pm ] |
If you take the thermostat & housing out, you can stuff a rag in there and push it up towards the valves too then drill/tap. Been there, done that. Or maybe a small vacuum too aimed right under the hole. |
| Author: | robertob [ Mon Aug 26, 2013 12:10 am ] |
I am pretty sure you don't need NPTF, usually automotive is just NPT. NPTF is a special-dimensioned version of NPT anyway. NPTF is supposed to give better sealing; I bet that the temp sensor you have is threaded NPT anyway. |
| Author: | emsvitil [ Mon Aug 26, 2013 1:32 am ] |
Quote: I am pretty sure you don't need NPTF, usually automotive is just NPT. NPTF is a special-dimensioned version of NPT anyway. NPTF is supposed to give better sealing; I bet that the temp sensor you have is threaded NPT anyway.
I'd use NPT and use sealant on just the outer portion of the sensor (so there's still some metal to metal contact) |
| Author: | Pierre [ Mon Aug 26, 2013 7:08 am ] |
Oh! are you saying you can find 1/4 npt but not 1/4 nptf? Yeah, you can cross the two... F just means no sealant necessary, think the formal name is dryseal. Use whichever tap you find, put sealant on it, call it a day. |
