It is currently Sun May 17, 2026 8:39 pm
PostPosted: Fri Aug 23, 2013 10:20 am
Hello,
I am sure this has been covered but I really looked and did not find a list of years cars that I can use as a donor car. My goal is to use as much of the parts as possible. I want to update brakes small ball joint and rear end as well.
The kickdown to run my weber.
Is there such a car out there?
As a side note what if I restore the 9" small pattern setup? I have been told the small ball joint is a weak spot and should be updated but the thing has lasted all these years....
Thanks for any help!!
66 Dart Wagon SL6
93 Dodge Truck S6
