| Distributor drive gear https://slantsix.org/forum/viewtopic.php?t=53161 |
| Author: | ceej [ Mon Aug 26, 2013 3:25 pm ] |
| Post subject: | Distributor drive gear |
The magneto is getting set up for the new rail. Based on what we are doing, the mag shop wants a Bronze gear to put on it. (It's going to have a pretty high load on it.) Anybody got a source for this gear? CJ |
| Author: | Joshie225 [ Mon Aug 26, 2013 4:25 pm ] |
The Aussies have one for their Bosch distributor. http://www.pentastarparts.com.au/store/ ... tail&p=612 They also have a steel gear, but don't specify which distributor it fits. http://www.pentastarparts.com.au/store/ ... ail&p=2493 Since these are made to mesh with slant six cams I would expect you could make one work with your magneto. Too bad you can't drive the mag off the cam. |
| Author: | ceej [ Mon Aug 26, 2013 6:06 pm ] |
Thanks Josh! Dan steered me to the modification thread for the bronze gear. CJ |
| Author: | Greg Ondayko [ Mon Aug 26, 2013 6:22 pm ] |
Quote: Thanks Josh!
Dan steered me to the modification thread for the bronze gear. CJ Care to Post that Link? I would like to know too! Thanks, Greg |
| Author: | ceej [ Mon Aug 26, 2013 6:40 pm ] |
Look down toward the bottom! http://www.slantsix.org/forum/viewtopic.php?t=38083 CJ |
| Author: | ceej [ Mon Aug 26, 2013 7:15 pm ] |
Contacted Spud. For the application he suggested steel would be the preferred material. CJ |
| Author: | DusterIdiot [ Mon Aug 26, 2013 8:08 pm ] |
| Post subject: | Uggghhh.. |
If I could access my "stash" I have a DG-404 in the misc. engine parts bin...it will be a while though... -D.Idiot |
| Author: | slantzilla [ Tue Aug 27, 2013 11:08 am ] |
Will it accept a standard Slant gear Ceej? If so I have an iron one in the box at my shop. |
| Author: | ceej [ Tue Aug 27, 2013 4:01 pm ] |
I'm not sure. It should be 0.500" shaft size. If you have an iron distributor gear, I don't know why it wouldn't. CJ |
| Author: | slantzilla [ Tue Aug 27, 2013 11:40 pm ] |
Should I wrap it in bacon for you? |
| Author: | ceej [ Wed Aug 28, 2013 6:24 am ] |
