It is currently Wed Nov 18, 2026 12:40 am
PostPosted: Tue Sep 03, 2013 8:21 pm
This might be a very basic question, but I need to remove the rear differential plug of a 1969 7 1/4 differential and I don't know what tool to use. The plug hole is neither a square, nor an Torx. Is it hexagonal? (Even though it looks like a weird design), or it is a proprietary tool?. Which size (1/2", 7/16")
I need to check that rear differential oil level, Thanks!
/6 Dodge Charger 69
Image...there's nothing like using the "Search" link above to solve most of your problems...
PostPosted: Tue Sep 03, 2013 9:25 pm
subscribed
Dave
1972 d-100 parts truck
PostPosted: Tue Sep 03, 2013 9:32 pm
Standard socket/ratchet tool: use your extension on the ratchet, 3/8" or 1/2" drive. (I can't remember which.) Years ago I faced the same cornfusion. P.
PostPosted: Wed Sep 04, 2013 7:27 am
Should be 1/2" double square. Your 1/2" drive ratchet will work fine.
PostPosted: Sat Sep 07, 2013 8:30 pm
Yes! It works! Thank you!!
/6 Dodge Charger 69
Users browsing this forum: Bing [Bot] and 5 guests
