| no reverse https://slantsix.org/forum/viewtopic.php?t=53222 |
| Author: | USAJon [ Tue Sep 03, 2013 9:42 am ] |
| Post subject: | no reverse |
looks like the rat dart w/old school trans act manual valve body has no reverse. it goes into gear and kinda moves but not over a small 2 inch concrete yard rise. plenty of fluid synthetic that looks clean. putting on exhaust pipes/glass packs so I can street drive and see how gears work... |
| Author: | bigslant6fan [ Wed Sep 04, 2013 9:02 am ] |
| Post subject: | . |
Did the Trans work before installing the valve body,was the low-reverse band adjusted to the correct specs for the model year trans |
| Author: | Joshie225 [ Wed Sep 04, 2013 9:39 am ] |
Don't you need to activate the trans brake to use reverse? |
| Author: | USAJon [ Wed Sep 04, 2013 10:01 am ] |
you know that's very possible as it was orig made 4race app ...old school. I did get a hand written note from previous owner stating something about putting it into reverse b4 activating the trans brake..will check it out. |
| Author: | Greg Ondayko [ Fri Sep 06, 2013 7:19 am ] |
Somtimes to reverse with the transbrake you Put it into "N" and then Push the button = "R" Greg |
