| Headlamps not working? https://slantsix.org/forum/viewtopic.php?t=53223 |
| Author: | kxracer728 [ Tue Sep 03, 2013 10:29 am ] |
| Post subject: | Headlamps not working? |
My headlamps have not worked since i've had the truck...All of the other lights work. From the testing that i've done i'm getting a good ground to the headlamp connector but i'm not getting 12v to the hot wire of the connector I've taken the dimmer switch off and it test good for continuity. According to the manual the yellow wire that runs from the dimmer switch to the headlamp switch is what sends the 12v to the head lamps I'm not getting 12v at the yellow wire were it connects to the head lamp switch. I don't think the head light switch could be bad if it allows the parking and side markers to work? |
