| Mechanical voltage regulator swap https://slantsix.org/forum/viewtopic.php?t=53236 |
| Author: | Brian [ Wed Sep 04, 2013 11:38 am ] |
| Post subject: | Mechanical voltage regulator swap |
Can the old style mechanical voltage regulator be changed to a solid state one? This is on a car running a electronic distributer, square back alternator with the old style mechanical regulator. I want to cut the wires, install the correct plug and run the newer style regulator. Is it that simple or am I missing something. Vibration under the hood concerns me. This is not a street driven car. |
| Author: | Fopar [ Wed Sep 04, 2013 11:55 am ] |
http://www.mymopar.com/charging.htm This should help you. Richard |
| Author: | Brian [ Wed Sep 04, 2013 12:13 pm ] |
Easy enough Thanks. |
