| Offenhauser 4bbl intake with 390 cfm holley!? Need help!! https://slantsix.org/forum/viewtopic.php?t=53258 |
| Author: | Mopar-haole [ Fri Sep 06, 2013 8:18 pm ] |
| Post subject: | Offenhauser 4bbl intake with 390 cfm holley!? Need help!! |
The bolt pattern from the bottom of the carb doesn't match the smaller bolt pattern on the offy, the holley has a much larger spread .. Anyone know of some sort or " pyramid " adapter that will work? |
| Author: | Fopar [ Fri Sep 06, 2013 8:51 pm ] |
Look at this and you will see the part you need to get the carb to fit, Clifford also had this. http://www.summitracing.com/parts/ofy-5 ... uiredparts Richard |
| Author: | Mopar-haole [ Fri Sep 06, 2013 10:39 pm ] |
| Post subject: | Offy 4bbl/ holley 390 |
Thanks for the link, that's the linkage I need? I just talked to the guy I got the intake from and he said he used to have an adapter plate or something. Any help is appreciated ! Spent this last Labor Day weekend pulling motors and transfer to get what I wanted to replace the /6 in my wagon. Scored some headers too.. |
| Author: | ceej [ Fri Sep 06, 2013 10:59 pm ] |
The adaptor plate is available from Offy, or Clifford. Cheaper from Clifford last I checked. http://www.cliffordperformance.net/Merc ... gory_Code= CJ |
| Author: | Mopar-haole [ Sat Sep 07, 2013 2:31 am ] |
Thank you sooooo much, I will post pics later |
| Author: | Joshie225 [ Sat Sep 07, 2013 8:35 am ] |
The Clifford adapter is also nicer than the Offy piece. |
| Author: | dartfordoor [ Sun Sep 08, 2013 12:08 am ] |
Is Clifford sending out regularly? If you order, would you get your stuff soon, Clifford had an iffy past....Jerry |
| Author: | Mopar-haole [ Mon Sep 09, 2013 8:42 am ] |
I'm not sure , ended up using a hand-me- down holley adapter, polished right up... |
