| Linkage for holley 390 in 1966 valiant? Help ! https://slantsix.org/forum/viewtopic.php?t=53285 |
| Author: | Mopar-haole [ Mon Sep 09, 2013 12:48 pm ] |
| Post subject: | Linkage for holley 390 in 1966 valiant? Help ! |
Anyone have any tips on fabbing a lil linkage for this? |
| Author: | VDART [ Mon Sep 09, 2013 2:18 pm ] |
get a cable system-from one of the after market companies-- you will need to switch the gas pedal to a cable style also-- unless you can find the 65-66 cable style($$) |
| Author: | Mopar-haole [ Tue Sep 10, 2013 4:07 pm ] |
Thanks for the response, I am going to attempt to make my own "custom" rod linkage to cable set up for it using a auto parts store cable kit and a spring and pulley . I think I got it figured out, will post pics soon |
| Author: | 65 dartman [ Tue Sep 10, 2013 4:46 pm ] |
Offenhauser made a linkage retrofit kit to use a 4 barrel on their manifold using a modified rode for the early A Body. I'd have to dig it out of my parts to see exactly what needed to be done. |
| Author: | wjajr [ Tue Sep 10, 2013 5:47 pm ] |
This is what I used for a 904 transmission, and cable : http://www.bpeusa.com/BPEtkdc.asp My 67 came with cable operated accelerator from factory, but a pedal from 67 on up including K Cars is easily mounted and connected to the above BPE accelerator cable bracket that is designed for Mopar factory cables. It is an easy install requiring no fabrication; you would need to drill a few holes in floor to mount a pedal, and cable.
| Author: | bmimken [ Tue Sep 10, 2013 9:12 pm ] |
wjajr is right. I have personally used that kit before, and it is very good. Brian |
