It is currently Tue Oct 13, 2026 4:10 pm
PostPosted: Mon Sep 09, 2013 12:03 am
Anyone have some sort of info on making this yourself? Trying to finish before Friday!
Aloha
1966 valiant 200 wagon
PostPosted: Mon Sep 09, 2013 12:27 am
what manifold and transmission are you running?
PostPosted: Thu Sep 12, 2013 8:07 pm
An offenhauser 4bbl from '89 and a 904 trAns. I need to figure out some sort of aftermarket set up cause Im an impatient bastard and messed up the original linkage from the firewall to the motor, the kickdown / spring on down to the pedal is still intact... Linkage to cable?
Thanks for the help
Aloha
PostPosted: Thu Sep 12, 2013 10:31 pm
you can get a new pedal/cable out of they junkyard out of an v8 abody or something comparable for the throttle cable. as far as the kickdown goes there is a company called lokar that sells a cable setup. or there is a writeup somewhere that uses a stock dodge kickdown cable. ill see if i can find it.
PostPosted: Thu Sep 12, 2013 10:42 pm
here is a good thread outlining the kickdown setup.
http://www.slantsix.org/forum/viewtopic.php?t=28812
here is one with pics of the lokar setup on the tranny
http://slantsix.org/forum/viewtopic.php ... e+kickdown
PostPosted: Fri Sep 13, 2013 7:17 am
I used a BPE kick down cable kit that is basically an off the shelf Mopar cable with all the fix’ens that bolts right up to a 904 or 727, and BPE universal cable mounting bracket. My car is a 67 so it came with cable operated accelerator. You can use most any cable operated accelerator pedal from ‘67 on up including any K Car derivative, Aspen, truck etc., until cable-less drive by wire accelerators that came in mid-2000’s, and adapt a shorter cable to it.
I had to shim factory bracket of accelerator pedal out from floor (this may be due to a non-factory replacement floor pan) to achieve full throttle opening on the 390, and use the Chrysler throttle shaft adapter to get transmission cable and accelerator cable to play nice with each other. It all installs in an hour or less, and can be dialed in quickly once installed. You will need one slightly longer carburetor mounting stud where cable adapter bolts to carburetor flange.
Yes, that is an o2 sensor to aid in carburetor tuning just below collector. My engine has a big cam with a lot of overlap that makes for very low idle vacuum, something a Holley 390 does not like, and this contraption helped a lot in sorting out jetting.
Users browsing this forum: Bing [Bot], Google [Bot] and 9 guests
