| super six distributor springs... https://slantsix.org/forum/viewtopic.php?t=53305 |
| Author: | DCFAB.US [ Wed Sep 11, 2013 5:33 pm ] |
| Post subject: | super six distributor springs... |
which springs came factory in super six distributors? I found a pretty good curve with the 11.5 vc, 9r gov, and two light springs but I just wonder what came OEM??? setup... 14 initial 9R govenor (18 deg) 11.5 vac can (tuned with allen for no pinging and havent re measured vac) |
| Author: | DusterIdiot [ Fri Sep 13, 2013 11:14 am ] |
| Post subject: | It's... |
Quote: I just wonder what came OEM???
OEM, is a heavy spring with a loop to allow the light spring to provide the governing spring rate up to about 14 degrees of advance before the heavy spring started applying it's force. I have found that in some cases (mostly lighter cars, that pulling the heavy loop spring and installing another light spring of similar rate provides a constant linear advance that is better for hi-po engines and is slow enough not to allow the pegs to slam off the end of the governor causing timing bounce during hard acceleration.-D.Idiot |
| Author: | DCFAB.US [ Fri Sep 13, 2013 9:39 pm ] |
Ahhh haaa... that explains the erratic issues with one spring removed! I ended up with another light spring... Runs better than with the heavy looped spring this way... I think iv'e reached the stock limits of VT and weber 38. I WANT MORE! |
| Author: | Rug_Trucker [ Sat Sep 14, 2013 5:24 am ] |
Quote: Ahhh haaa... that explains the erratic issues with one spring removed! I ended up with another light spring... Runs better than with the heavy looped spring this way... I think iv'e reached the stock limits of VT and weber 38. I WANT MORE!
Looks like you and I will be competing for the slant parts two Saturdays from now at the swap meet! |
| Author: | jhdeval [ Sat Sep 14, 2013 8:13 pm ] |
Woah woah woah. I am not far from Nashville/Chatanooga where is this swap meet if I may ask? |
| Author: | Rug_Trucker [ Sat Sep 14, 2013 9:33 pm ] |
Quote: Woah woah woah. I am not far from Nashville/Chatanooga where is this swap meet if I may ask?
Events calender. Lebanon TN Sept 28th. Music City Mopar Show.http://musiccitymoparclub.com/MusicCity ... inal-1.pdf |
