| OLD battery charger - should I avoid using? https://slantsix.org/forum/viewtopic.php?t=53311 |
| Author: | crater [ Thu Sep 12, 2013 12:00 pm ] |
I don't have an answer for you, but my god that thing would be awesome to just have in the house as a fine piece of art. |
| Author: | mattelderca [ Thu Sep 12, 2013 12:27 pm ] |
Yeah, don't use that one. Look for one with an AGM (absorbed glass mat) setting for optimal results. You can of course still use this one for any FLA (flooded lead acid)batteries! |
| Author: | sandy in BC [ Thu Sep 12, 2013 3:34 pm ] |
Dont know nuffin about Optima batteries. ........but I probably have 8 or 9 batteries of the convenional type in use at all times around here. I use an ancient Bulldog Charger that looks and smells like the one you ha. At most it will charge 3 amps. Charging overnight with a charger like this is the safest way to bring a battery up. Keep the Sears one for your regular batteries. After all its "full wave" |
| Author: | olafla [ Thu Sep 12, 2013 5:40 pm ] |
I totally agree with sandy in BC. My charger is one of my oldest and dearest tools, I bought it in the late '60s/early '70s, I keep it in it's original box, and I use it regularly. Mine can pump out 6 amps max, and then it slowly trickles down to 1.5~2 amps after a day or two. All conventional batteries love slow charging with small charge currents, a speedy charge will usually shorten the battery's life, unless it is made with a sophisticated (expensive) pulse charger. Check the wires for cracks, and replace them if necessary. And besides, they don't make such high-quality, good-looking things anymore! Olaf |
| Author: | emsvitil [ Thu Sep 12, 2013 8:46 pm ] |
I'd use it until the battery hit 14.4 volts. Then disconnect. |
