It is currently Fri May 15, 2026 12:57 am
 Post subject: power steering fluid
PostPosted: Fri Sep 13, 2013 9:52 am
I have finally decieded to put on a new PS pump and with all the drifferent brands out now a days I would like some recommendations on a brand of PS fluid to use. Thanks in advance.
my first 6 1973 Plymouth DusterImage
PostPosted: Fri Sep 13, 2013 10:21 am
I use the cheap kind. Seriously, I don't see how there will be much difference in performance between brands of power steering fluid.
PostPosted: Fri Sep 13, 2013 6:38 pm
Maybe go with a synthetic? Hellzbellz the dually leaks and I just dump any type ATF I have sitting around. I usually have some Honda fluid in the bed I pour in with every fill up.
PostPosted: Sat Sep 14, 2013 9:54 pm
Beautiful Duster! All you other guys, don't get your hackles up, but that is my favorite A body. Love it well.
Sam
PostPosted: Sun Sep 15, 2013 5:59 am
Most other manufacturers recommend ATF, but not mother Mopar! I don't have my manuals available where I sit right now, but I distinctly remember that the '78 manual says: 'Do not use ATF, only use original Mopar power steering fluid'.
I don't know if it only a sale gimmick, but the fact is that after filling up first with an ATF for a very short time, and then replacing it with a US made power steering fluid 'designed to be used on ALL cars' last spring, the sector shaft seals are now leaking badly...
Sam, agreed, but yours is not bad either!
Olaf
Aspenized
PostPosted: Sun Sep 15, 2013 8:32 am
Thanks Sam and olafia but don't be fooled she does need a paint job. As for the PS fluild I picked up some Prestone that was on sale for a good price. I will tell everbody this make sure you have a good puller for the pully I almost gave up after 45 mins. of working on it when afer 1 more turn I heard a small pop and she finally gave way and started coming off.
