| Full front lower pan done. https://slantsix.org/forum/viewtopic.php?t=53330 |
Page 1 of 2 |
| Author: | dartsport76 [ Sat Sep 14, 2013 8:10 pm ] |
Looks sharp! Makin' me get ideas... lol! |
| Author: | emsvitil [ Sat Sep 14, 2013 9:03 pm ] |
| Author: | Sam Powell [ Sat Sep 14, 2013 9:29 pm ] |
Quote: ![]() Sam |
| Author: | 383charger [ Sat Sep 21, 2013 7:17 am ] |
Great Job. How long did it take you to make? |
| Author: | Sam Powell [ Sat Sep 21, 2013 8:38 am ] |
Thanks. That took a week to fit the top part with the air dam, and several evenings to fit the bottom pan. I had fitted a cover that extended from the radiator core support to the K frame last year. This pan ties into that cover in the center.. One big mistake which I want to go back and engineer a fix for is the lack of a trap door to access the radiator drain. I will wait until I must drain the radiator again to tackle that one. The project just got out of control and became bigger than anticipated to start. I painted it Thursday evening then left for a weekend at the beach. Sam |
| Author: | dartsport76 [ Sun Sep 22, 2013 12:20 pm ] |
| Post subject: | Tested? |
Have you had a chance to test this yet? if so did it provide the stability and fuel efficiency? |
| Author: | Sam Powell [ Sun Sep 22, 2013 6:39 pm ] |
It would very hard to do good tesearch here. I change too many things to know for what caused what. I did drive it last week about 30 miles on the highway but could not tell much. Traffic was heavy and never got above 55. I plan on aligning the front end to put more caster in it. It is set at only 1.5 degrees now, and this leaves it a little antsy at speed. I want at least 4 in it. Sometime I plan on making another extended highway drive as I did on the drive to Lou's this Summer. That may tell me something. Thanks for asking. I was a little torn between extending the airdam out far enough to shield the wheels and keeping the appearance of the front fender profile stock looking. I chose to stop the air dam inboard more than ideal. But I like the look. Sam |
| Author: | 383charger [ Mon Sep 23, 2013 1:52 am ] |
| Post subject: | Let us see a photo |
Let us see a photo when you paint it. |
| Author: | Sam Powell [ Mon Sep 23, 2013 4:29 am ] |
| Post subject: | Re: Let us see a photo |
Quote: Let us see a photo when you paint it.
Now in my signature. Sam |
| Author: | Sam Powell [ Mon Sep 23, 2013 4:30 am ] |
Done. Sam |
| Author: | dartsport76 [ Mon Sep 23, 2013 5:11 pm ] |
are those fender vents functional?! and I think your bumper looks sharp too! |
| Author: | olafla [ Mon Sep 23, 2013 5:49 pm ] |
Quote: Since no one else will ever see the bottom of the car, you folks are the only ones I can show this off to.
Naah, you've got room for a mirror in the trunk, Sam! Do like the guys in auto shows, flaunt it! |
| Author: | Sam Powell [ Fri Sep 27, 2013 6:51 pm ] |
Quote: are those fender vents functional?!
Thanks. Yes the fender vents are functional. They could stand to be way bigger. and I think your bumper looks sharp too! Sam |
| Author: | 64ragtop [ Sat Sep 28, 2013 4:41 pm ] |
And the fender vents pull from the engine compartment?? Letting hot air out there might help with cooling. Proper hood to radiator & hood to cowl weatherstripping could help airflow thru the radiator. BC |
| Page 1 of 2 | All times are UTC-08:00 |
