It is currently Sun Jun 21, 2026 7:25 am
PostPosted: Tue Oct 08, 2013 5:24 am
Ok, so I knew I had a leaky wire (it appears to be the primary coil wire), because every time I change the timing (still messing with it, actually) I get a little shock.
Had a little insomnia tonight and checked the wires, and at least one and possibly more is leaking. But the weird bit is that I can actually SEE the HEI coil sparking. It's the full-GM truck setup with the heat sink.
This can't be good, right? Am I missing something?
63 Plymouth Valiant V200 Convertible.
225, HEI, Super Six with 38/38 Weber, Electric Fans, Scarebird discs, FirmFeel front swaybar.
PostPosted: Tue Oct 08, 2013 10:21 am
The coil insulation is shot. You need a new coil. Check your cap and rotor for wear and all your wires for resistance as that puts more stress on the coil.
PostPosted: Tue Oct 08, 2013 4:40 pm
Well, the thing was used in the first place, so I went for the change. Feels a little better. I'll do a seeing eye check when it gets dark.
Thanks!
PostPosted: Wed Oct 09, 2013 7:04 am
And we have a winner!
Thanks again. I thought the coil wire was bad, but it turned out that it was just the coil. It all looks nice and invisible now. :)
PostPosted: Fri Oct 11, 2013 4:50 pm
Anytime I suspect a problem with ignition secondary, I do a "wet test". Fill a spray bottle with water & a teaspoon of salt. Spray it on plug wires, distributor cap, & coil of a running engine- (if needed, put the trans in gear while applying the brake & give it some gas to load the engine).
If the engine now runs rough & misfires then you found a weak part- repair as needed & retest. If it runs ok then rinse off the saltwater & keep on driving!
63 Valiant Wagon
225 - 4 bbl
